  #36 (permalink)
Old 02-16-2014, 01:54 PM
David Hodgson's Avatar
David Hodgson David Hodgson is offline
DRB torana based front suspension used rack and pinion, so probably not that. Sounds like mine with Crown front end and jag rear. This is not a bad set up if it's done right, just gotta get past the stigma that the old crown kits earnt. The chassis rails will tell you how much of the crown was used.
It is definitely not a G-Force body. Could be an early Autostyling body. Not many kits used the wider tapper Mini headlight rims.
Whatever it is the body work appears very well finished.
SLIPRY
