Old 02-16-2014, 04:30 PM
patrickt patrickt is offline
The problem with the Cobra soft top design is that when you insert the holding pins in to the slot on the windshield frame, then fasten the side clasps but don't cinch them down, the next step is to get the two back lift-a-dots fastened. If the top is tight, and cold, then when you pull down on the top to try and get the two back lift-a-dots down, the pins pop out from the top of the windshield frame. I can't tell you what a PITA it is. What is really irritating is when you do manage to get the two back ones down, then you alternate around, and you're almost done, and you pull hard, and the damn pins up front pop out.
