Originally Posted by jwd
DO NOT put a mechanical fuel pressure gauge in the cockpit unless you use an isolator. Running a fuel line under pressure into the passenger compartment is really stupid.
Thank you. I should have been more clear about that. For the same reason, an
oil pressure line inside the cockpit is not a good idea either.
I have found a fuel pressure gauge to be the most useful gauges in trouble shooting both EFI and carburetor engine problems.
