Old 02-18-2014, 09:06 PM
Jethrow's Avatar
Jethrow Jethrow is offline
Cobra Make, Engine: FFR Mk4 Roadster, LS3, TR6060, 8 3/4"
Originally Posted by Paintwerks View Post
Hi Muzza, yes, I have sourced the correct-spec gearbox for the car. It's the 6 speed Tremec TR-6060 'MG9' variant as fitted to the ZL1 Camaro and current model VF GTS. The gearbox features oil cooler support which is nifty. I wonder if you'd need to run a trans oil cooler in such a lightweight car?
I think I have the same g'box behind my LS3 and I was told that if I did not want to run the cooler then I had to plumb the outlet to the inlet else the g'box oil pump could cavitate. So I elected to fit the cooler.
Also, the cooler kit as supplied actually mounts the cooler to the side of the gearbox, so that is where I put mine.
Tim
FFR Mk4 Roadster
HSV Clubsport R8
