Old 04-02-2002, 12:43 PM
ronzara's Avatar
ronzara ronzara is offline
Cobra Make, Engine: Everett-Morrison 351w assembly STILL in progress
Send a message via AIM to ronzara Send a message via Yahoo to ronzara
Default Alternator Connection ???'s
I have solved my 351W alternator bracket problem by cutting off 2" of the mounting end of a 302 bracket. Then by redrilling a new hole, I was able to mount it to a lower water pump bolt. The top of the alt, I mounted with a 6" bolt and a spacer into the top/front Head mounting hole. A 30" V belt aligned the alt perfectly in the center of the adjuster bracket.
Now my question... The Motorcarft Alternator I have is an older style, with 4 poles on the back. They are labeled:
STR
BAT
GND
FLO
obviously... BAT = Battery, GND = Ground
What is STR and FLO
Where & how do these connect?
Is there any thing else I need in-line between the Alt poles and their destination?
Is there a harness made for this?
I know this sounds like a bunch of dumb questions,... but the electrical stuff isn't my forte!
And as they say the only dumb questions are the ones you don't ask! Thanks for your help!
Ron Zara
ronzara@hotmail.com
1. "Putting a Chevy Motor in a Shelby Cobra is like CUSSING IN CHURCH!"...... ME
2. "Friends Don't Let Friends Drive Junk"....
