Old 02-24-2014, 05:36 PM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
My EM has the C4 IRS under it ---on your 5 link rear does the 5th link locate the housing side to side????? if so you need to adjust it to center / line the pinion with the trans output shaft as the side angle combined with the vertical angle gets nasty---------
And the housing will probably rotate with the up/dowm travel of the housing in addition to any torque twist on accer/deceleration and or hard braking (twist the housing)
