The Zero degree reading at the trans seems unusual as most engines slant more than that, usually around 3 degrees. Unusual problem. Could always raise the front of the engine at the mounts to tip the trans down, then bring the pinion up to within the 1 degree or so difference, if you have the room body to header clearance, but maybe you already considered that...
