Old 02-24-2014, 08:51 PM
mjhcobra's Avatar
mjhcobra mjhcobra is offline
Cobra Make, Engine: Everett Morrison, 428
Final check with the drive shaft out and the car on level blocks. Trans and diff both at exactly ZERO degrees on the angle meter. Each location checked on multiple surfaces - all are at ZERO, and yes the meter is bouncing, its not stuck on Zero.
Tomorrow after work I will begin by kicking up the pinion angle-not much else to move.
