Old 02-26-2014, 10:39 PM
frdfver's Avatar
frdfver frdfver is offline
Cobra Make, Engine: N.A.F., 351 cleveland, 9" ford
Although that differs from most text or schools of thought they are supposed to be the experts. Will 3-5 degrees alone at the pinion be enough to get the bind out and if it does at ride height will it still bind as the rear axle moves down through the suspension travel. If it works at least that’s easy and you don’t have to mess with the side pipes. Hope it works out for you with no vibration and the u joints hold up. I also would still put some clearance reliefs in the yoke just to be safe…..
Paul T.
