  #37 (permalink)
Old 03-03-2014, 02:56 PM
1795's Avatar
1795 1795 is offline
He thought that I would just have to disconnect it, so that it was loose and cut a few cable ties on the wiring harness to loosen things up. He said that I may have to unbolt the windshield and tip it forward to access the screws on the deflectors for hooking up the vent tubes; however I found this nifty little right angle Phillips had ratchet that may have enough clearance to get the job done without loosening the windshield. Will let you guys know in a few days, it is single digits out right now and will be below zero tonight. A little too cold for me to be messing around with things.
