Old 03-03-2014, 04:13 PM
mtrain2000's Avatar
mtrain2000 mtrain2000 is offline
Cobra Make, Engine: Shell Valley
Originally Posted by Mdman352 View Post
I use a LM 1 as well. I use bungs welded into the exhaust pipe at the front of the collector. If you mount the bung towards the inside of the car there is no need to re-coat the pipe as it cannot be seen except from under the car. The LM 1 will do a much better job than an ear ever will. Well worth the money.
Yes, make SURE you mount it somewhere on the collector as ANY exhaust leak with throw the readings off, ask me how I know.
I've got an LM1 on a twin turbo truck, and I mounted it just after the collector as the headers were already in the truck.
Well, even with a V-band exhaust clamp I still have a very slight leak which drives the AF gauge wild. So guess what I will have to do all over again.............
You can put a chebby engine into a Ford body, but it will NEVER be a chevrolet. It also shows you're ignorant, and lack imagination, as in its been done to death as in its not an original idea.
