Old 03-04-2014, 05:00 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
The addition of a relay to power the fuel pump is a great idea too. The wire powering the fuel pump goes back and forth to the dashboard switch. A bit long in my opinion for the wire gauge. The holly red requires no fuel pressure regulator either. If you go to a local parts house look for a vibration isolation washer kit. Related somehow to windshield washers or wipers as I recall basically a thin rubber disk with metal washers on the ends, quiets down the pump as does the relay.
SPFWiringDiagrams@Comcast.net
