Old 03-04-2014, 04:20 PM
Sideways's Avatar
Sideways Sideways is offline
Originally Posted by Blas View Post
The addition of a relay to power the fuel pump is a great idea too. The wire powering the fuel pump goes back and forth to the dashboard switch. A bit long in my opinion for the wire gauge. The holly red requires no fuel pressure regulator either. If you go to a local parts house look for a vibration isolation washer kit. Related somehow to windshield washers or wipers as I recall basically a thin rubber disk with metal washers on the ends, quiets down the pump as does the relay.
I have some evaporator fan rubber 1/4 " thick soft washers that should help with the noise but after I fire it up the noise from the pipes will bury any noise coming from the fuel pump.
Good thing I didn't decide to go Holley Blue as that would need a pressure gauge and relay.
Glenn
