Old 03-05-2014, 07:52 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
The grey you are referring to connects in the back of your Tach gauge. You do not need the MSD 6AL because your distributor is a STAND ALONE unit. Be sure and match your distributor gear with the type of cam you are running. If you are running an aftermarket cam I would strongly suggest a steel distributor gear. You will have to buy that seperately but it might save you a lot of roadside dissappointment.
Clois Harlan
"Let's roll"
"Be part of Something Good
