Old 03-05-2014, 08:26 PM
lippy lippy is offline
Lippy, what is that makes you think your carb is not set right?
(1) Runs on after stopping sometimes. Not that bad, but it does go for 1s or so. Could just be bad gas or ignition, but I retarded the timing from 36 to 34 (full). Problem still present. (2) It was stumbling when I gave it throttle. I changed the acceleration pump nozzles to 37s and I think that did the trick. (3) Plugs fouled. My first coil was out of spec and I replaced it, and hope that did the trick.
This is a pricey engine and I want to make sure it's operating within range for a carb'd car. With a sideband, I can verify and optimize.
Also, the fuel was percolating when I stopped. I added a 0.25" phenolic spacer and I *think* that fixed the percolation.
