Old 03-08-2014, 11:52 PM
RGF RGF is offline
Cobra Make, Engine: Pace 427 - completed and on the road!
Default Front & Rear Brake lines
Front lines fitted - note all are pre-shaped/bent so there is no need to shape them to fit
This shows where the front brake lines will meet up with the brake cylinders on the pedal box to be fitted later
Fitting the rear brake lines to the tunnel
As rear brake lines exit the tunnel. Note that I filed the chassis edge and rounded it slightly to avoid wear on the brake line at this point
Rear brake lines fitted (note fuel line is also visible here)
