Old 03-09-2014, 12:48 PM
buddyg's Avatar
buddyg buddyg is offline
Cobra Make, Engine: Superformance #1309 www.spfowners.freeforums.net
How much would my 351 with 4400 miles be worth?
Rocker arms - 1.60 ratio, M-6564-B351 Ignition timing - 32°@ 3000 RPM Rated HP - 430 HP @ 5500 RPM Torque - 450 ft. lb. @ 4000 RPM
M-6007-A392 ENGINE SPEC SHEET
Bore x Stroke - 4.030" x 3.850"
Piston specs - 1.615" compression height, dish + notch volume = 15 +/- .5cc
.912" floating pin w/ single wire lock rings, 1/16", 1/16", 3/16"
Grant CC4000H030 or Speed Pro R9902 +.030 ring pack Nominal compression ratio - 9.7:1 (range is +/- .5)
Deck height - 9.50"
Piston to deck - 000" min. Camshaft - hydraulic roller,
max valve lift
duration @ .050" lift
cam timing @ .006", open
Int. C/L Exh. C/L .566" 108° .576" 116° 232° 240° 29°BTC 77°BBC
Hydraulic roller lifters - M-6500-R302
Cylinder heads - M-6049-X303 w/64cc +/-2cc chamber volume
Valves - 1.94" int. (M-6507-J302) / 1.54" exh. (M-6505-G302)
Valve springs - M-6513-A50 single w/damper, 110 # @ 1.820" installed height,
close 73° ABC
33° ATC
240 # @ 1.400" open
Superformance specific forum check it out!
http://spfowners.freeforums.net/
