Old 03-10-2014, 12:59 PM
madmaxx madmaxx is offline
Yes there is a ground wire in the trunk from the battery to frame. It breaks at the terminal where it connects the frame. Pull up the carpet behind the battery tray and remove the terminal, its the only way to inspect. You should have noticed your amp gauge going crazy though.
Originally Posted by lippy View Post
Did you check your ground, battery, and starter?
