Old 03-11-2014, 02:47 PM
Cobra01 Cobra01 is offline
Cobra Make, Engine: Absolute Pace 427 SC
Originally Posted by sambo View Post
Is that a bespoke steering column or from a donor vehicle? I don't see any webbing for the collapsible section - not saying it doesn't collapse, just curious as I'd like to replace my Ford Laser column one day.
Hi Sambo,
The steering column does collapse It is specially made by Absolute Pace.
From Memory there is a long rivet through the inner and outer shaft that make up the steering column.
Here you can see the outer part of the column which supports the steering shaft as it goes through the firewall of the car to the universal joint then on to the Rack and Pinion .
There is a bearing bolted to the firewall for support .
Brad
There is nothing better than a cold beer
