Old 03-11-2014, 11:22 PM
Rick Parker's Avatar
Starting issues could be the old school Ford type starter solenoid on the firewall if it is used but that would not affect drivability after warm up. You've got a heat induced open circuit in the primary ignition system, might even be in the fuse panel. But I would check inside the distributor.
Rick
