Old 03-12-2014, 01:44 AM
Ron61's Avatar
Ron61 Ron61 is offline
Post
I agree with the heat causing the problem, but even if the distributor is bad, that shouldn't keep the motor from turning over. I would get a remote starter and run it where there is no traffic until it stops and then start using a VOM to check for voltage at the starter and other key points. The loose ground is sounding more and more like a possibility and seems to be one of the key causes of these cars having weird problems. It is possible the starter is shorting when hot, but I doubt that.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
