Old 03-14-2014, 11:12 AM
Z-linkCobra's Avatar
Z-linkCobra Z-linkCobra is offline
Cobra Make, Engine: Everett Morrison, All aluminum small block ford.
What are the temp readings when your having this problem? If its not getting hot then you could have too much water in the system. I know that sounds ass backwards but you need some room for expansion. Empty your catch can and as long as your not getting hot let it level itself out. I have had several cars through the years that would spit coolant down to a certain level and be just fine.
Is this a new build or something you have run for some time? If its a new build and its getting hot your head gaskets may be installed wrong.
" If it wont break em loose in 3rd gear, it aint enough power "
