Old 03-15-2014, 08:29 AM
STEVE-O STEVE-O is offline
The bouncing ammeter in the SPF indicates that your voltage system is overcharging which results in MSD ignition issues, killed coils and dead batteries. Sounds like you do not have a 1 wire alternator? If that's the case, the wiring change to correct overcharging ( a simple one, I may add) can be found in the SCOF technical library.
If you own an SPF it is well worth the yearly membership fee to join.
They also have a fix for cooling the carb which may also be part of your heat related issue.
Superformance Owners Association
