  #22 (permalink)
Old 03-16-2014, 07:48 PM
Ant Ant is offline
Default Dry sump venting open or closed
As you have similar to me with Reg installation, I would prefer to have the pop off valve coming from the fuel pump cover plate rather than the valve cover, but I don't want to run vacuum all the time so will probably weld a fitting on valve cover to take a -10an line to the puke tank, the problem maybe with the Dailey pump is it spins at 75% engine rpm so -10 may not be large enough for a breather as it may still have a few in/hg of vacuum...
Reason I want to run a breather on the road is the car may do some minimal slower running and I don't want a lubrication issue, and with final break in using no vacuum...
A J. Newton
The 1960's rocked!
