Old 03-18-2014, 10:47 AM
Z-linkCobra's Avatar
Z-linkCobra Z-linkCobra is offline
Cobra Make, Engine: Everett Morrison, All aluminum small block ford.
Let me throw something out there for thought. Im running an all aluminum 302 with a weaver brothers 5 stage pump. Closed valve covers, tank is vented to puke tank with an air cleaner. I was thinking of running a line from the bottom of my puke tank back over to the motor and allow the vacuum to pull any oil out of the puke tank back into the motor.
I realize that what comes out of the puke tank sometimes doesn't look to good. It did however come out of the motor and nothing but a little moisture in the oil. I run a belt drive distributer and crank trigger. I was thinking of tapping into the distributor hole plug and running in right there.
Thoughts?
" If it wont break em loose in 3rd gear, it aint enough power "
