Old 03-19-2014, 09:34 AM
michel schryer michel schryer is offline
Cobra Make, Engine: D&D Cobra,302 stock for now,IRS
Send a message via Yahoo to michel schryer
You have a point but with the coolant flowing faster through the engine it doesn't have the time to overheat because it flows constantly and still pass through the rad, that's what I read in an article about that and why do big companies make high flow pumps if it gets trapped in the rad waiting to past the thermostat. Anyway I will keep the thermostat for now and buy a 2qz recovery tank from Breeze automotive or Canton, it should solve my problem , thanks bud !
Originally Posted by CHANMADD View Post
Hey........without a thermostat it may appear to run ok................the coolant will eventually be passing through the radiator so fast that when it returns to the engine via the lower radiator hose it will not have spent enough time in the radiator to cool, ...so it will return hot and just get hotter and hotter.....
