Old 03-19-2014, 10:43 AM
FWB's Avatar
FWB FWB is offline
Originally Posted by mjhcobra View Post
Hi Guys,
Everett Morrison's directions for modifying the front coil springs from a Mustang II front end were to cut several of the coils off and use the spring. Unfortunately, this leaves the end portion of the remaining spring that I am to use not being able to sit properly on the lower control arm. It looks like it could just pop out of the spring perch on the lower control arm.
Is there an aftermarket spring manufacturer that makes a replacement spring with the correct geometry for the Mustang II front end that would mate better with the factory control arms and would be the correct length for my Cobra?
EM's directions were to cut a certain amount of coils off depending on the engine size and the ride height you wanted. Seems a little ancient to me.
while i'm not fully versed on the components of an EM.
if your doing suspension work and the car uses factory stamped steel mustang II arms and springs, you may want to look into upgrading to aftermarket tubular upper and lower arms that use coilovers. if your suspension is over 20 years old i'm sure some of the bushings have also seen better days.
i did exactly this to my car, and installed an upper and lower kit with coilovers from Heidt's suspension. i also upgraded the brakes while i was at it too......was a great decision, made the car feel so much better on the road.
Fred B
