Old 03-19-2014, 12:20 PM
mnm99's Avatar
mnm99 mnm99 is offline
Here are the stats on the car. Engine built in 2007 408 stroker , all forged alum heads...bla.bla.bla. It's built well. Cobra stats
Options from Hurricane:
Stage 1 suspension assembly upgrade
Limited slip upgrade
Aluminum firewall upgrade
Polished stainless quick jacks
Ceramic coated side pipes (silver)
Fully adjustable coil over upgrade
Frame coating
Windshield wiper kit
Heater kit (vents hidden under dash and blowing into foot well)
Wind wings
Engine:
351W stroked to 408CI
Built by M&R Engines of Glendale, CA, dyno-tuned at over 450hp
Aluminum heads
Aluminum radiator
Edelbrock hi-flow water pump
Full roller (cam and rockers) (COMP Cams Xtreme Energy Camshaft)
Forged internals
770 Holley avenger carb
Polished aluminum air cleaner and valve covers
Custom headers with ceramic coated side pipes
Transmission:
Tremec T-5 with 2.95 first, 1.94, 1.34, 1.00 and .63 overdrive
Tremec T-5 bell housing
10.5” stage 2 clutch kit
Correct forward facing shifter
Suspension:
4-wheel coil over suspension with QA1 adjustable shocks and rear panhard bar
4-wheel discs with wildwood master cylinder
Narrowed ford 9” rear with 31 spline axles and 3.50 posi
Torque thrust II wheels with nitto NT 555 P275
Interior:
Black leather interior with correct low back racing seats and custom fabricated leather door panels
Autometer gauges with correct reverse speedometer
Dorsett Black carpet with Jutte padding and full dynomat insulation
Paint and Misc:
Galaxy Blue Pearl with silver stripes buried perfectly so no visible lines or ridges
Fully finished and carpeted trunk with custom truck panels and hidden battery compartment
Custom stereo with custom amp rack and custom control panel under dash
