Old 03-20-2014, 04:49 PM
Ant Ant is offline
Default Dry sump venting open or closed
Originally Posted by PLDRIVE View Post
If the engine goes from pulling a vacuum to positive pressure it could blow out a seal in the engine. The Peterson pop off spring pressure is more for catastrophic failure then repeated positive pressure cycles. My knowledge is not from personal experience, its from my engine builder (He builds dry sump engines on a weekly basis).
I would consider cost of a spring cheap insurance.
MP
I gotcha and that makes sense. The valve cover pop off has a very light spring hardly enough to seat it so I guess that won't take much pressure to work..I might consider leaving that there, and if I want minimal vacuum I can adjust regulator down to 2"
A J. Newton
The 1960's rocked!
