Old 03-23-2014, 07:18 PM
damage's Avatar
damage damage is offline
Cobra Make, Engine: Kirkham 427SC 482 Cammer
Quiz question for you guys with aftermarket EFI systems.
What are you using for an ignition switch (brand type etc).
I had one of those Lucas style key switches in the car as part of the delivery from Kirkham but this switch has a momentary interuption of power to the ECU on cranking which is playing havoc with getting the engine started because the ECU stop starts.
I need a switch that guarantees a continuous supply to the ECU when switching from run to cranking, or would it just be easier to run a start button with isolated relay supply.
