Old 03-24-2014, 12:11 PM
dan512 dan512 is offline
Originally Posted by Cheesehead View Post
Dan,
I live in the Netherlands. My SPF has a 351W stroked to 427 cu (7lt). I use Valvoline VR1 20W50. Cold oil pressure is about 65 psi and hot about 62 psi. This is racing oil and it has more ZDDP as normal, which is good. Not for modern cars with a catalytic convertor in the exhaust. Just for old cars or racing cars. Sold for prices around 50 euro's for 5 lt Not cheap, but good stuff). My engine takes about 5 lt.
Do a search on the internet and you will probably find a dealer that can send it to you. I buy 10 lt at a time, which saves some shipping costs and I have some spare oil.
Good luck.
BTW It normally is good practice to stick with the oil the engine builder recomments.
Good tip with the VR1 oil. I'll look into it
Do you mean oil pressure at idle? I always read that anything above 20 psi at idle is fine and then it should go up approx 10psi per 1000rpm.
Can someone enlighten me what oil pressure to expect? Yesterday with the oil at around 70C or 160F, I had around 45 psi at 3000rpm. Didn't push it since it was too cold for the engine to warm up.
