Old 03-24-2014, 04:17 PM
bskier bskier is offline
Default Ignition Problems?
Hello... I'm running a 428FE in SPF 1001. Car is absolutely immaculate, not raced, just used for shows/cruising. Lately I've noticed that after the car warms up ~20min or so, it begins to stumble then surge. As you can imagine, there had better be about 1000 ft in front of me before I let out the clutch! This becomes more apparent if I stop the car to run errands, etc. get back in and start after 15 min or so. Car stumbles and flames out. I can restart, but it stumbles/surges until I make it back home. Usually, back road cruising is not a problem when the engine is under constant load. It seems to be a problem after it warms up and I'm in heavy traffic, or stop and then try to start it 10 - 15 min later.
Ignition coil issue perhaps? Any suggestions greatly appreciated.
Thanks,
Brian
