Old 03-25-2014, 08:59 AM
patrickt patrickt is offline
Originally Posted by Gaz64 View Post
Fuel in carb is percolating.
What carb? Do you have any heat shielding?
Always a possibility. Brian, if cleaning the air bleeds doesn't fix it, and your floats are set right, use an infrared temp gauge to see how hot your bowls are -- if they're over 200 degrees, try fashioning a temporary Turkey Pan out of aluminum foil layered several times over itself and take her for a test drive. Try and do identical "before and after" test drives. See if your improvised TP improves it.
