Old 03-25-2014, 11:15 AM
Z-linkCobra's Avatar
Z-linkCobra Z-linkCobra is offline
Cobra Make, Engine: Everett Morrison, All aluminum small block ford.
Not knowing what you have for a distributor that timing does seem awful low. Does your distributor have vacuum advance, mechanical advance or both? Small block likes about 30 degrees max depending on the fuel your running. A lower octane fuel will not let you get away with more than about 27 or 28 degrees max.
" If it wont break em loose in 3rd gear, it aint enough power "
