Old 03-25-2014, 03:45 PM
bskier bskier is offline
Default Carb temperature
Always a possibility. Brian, if cleaning the air bleeds doesn't fix it, and your floats are set right, use an infrared temp gauge to see how hot your bowls are -- if they're over 200 degrees, try fashioning a temporary Turkey Pan out of aluminum foil layered several times over itself and take her for a test drive. Try and do identical "before and after" test drives. See if your improvised TP improves it.
Thanks to all for the replies!! I am running a Demon (will have to check size) The fuel percolation theory in an earlier reply may explain why it runs just fine as long as your are moving, or it is cold, but after a warm up period then getting into stop and go traffic, or parking for 20 minutes or so, the flame out, rough starting and surging begins.
I will definitely clean out the carb and try some heat shielding. Thanks to all for the help!
