Old 03-25-2014, 06:32 PM
joyridin''s Avatar
joyridin' joyridin' is offline
You did make a personal attack. Instead of just asking about the product, you had to say I was full of it.
And contrary to your theory, it is used in all industries. The company that has the product I use manufactures specialty bearings for all industries. I suppose if you need to find finite compositions, you might look elsewhere, but for 95% of the applications it is totally accurate. It can easily pick out one heat lot from another as long as you are determining chemical composition and not hardness.
It can pick out any type of stainless you put in front of it along with a breakdown of the chemical composition. I would say if you haven't used one, you really don't have a lot of talking room. For the topic on hand, it will easily determine the material used and the chemical properties.
