Old 03-26-2014, 04:27 PM
sambo's Avatar
sambo sambo is offline
Originally Posted by Tonus72 View Post
I figure these cars really do not need a 6 speed, especially the way I plan to drive mine (ie very carefully!!)
Tony, I just had a look at TKO600/T56/Magnum ratios on Tremec's web site and the 6th gear on a T56/Magnum is typically lower than the 5th gear on a TKO, with 4th gear on both boxes being the same ratio, ie, 1.00.
Have you worked out your engine RPMs at highway cruising speed? A second overdrive might be preferable.
TKO ratios
T56 Magnum ratios
"A spectacularly fast car in a grand if dated tradition."
