Old 03-27-2014, 01:41 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
A vehicle running closed loop engine management will use more fuel the higher the ethanol content goes.
O2 sensor activity and the target A/F ratio sends fuel trims positive to make up the difference.
Fuel consumption order worse to best E85, E10, 91, 95, 98 PULP, as tested for a local TV report.
Carbs require recalibration for anything over 10% ethanol.
Stoich ratios for fuels: petrol 14.7:1, ethanol 9.5:1, methanol 6.5:1 approx.
Obviously best power ratios are richer.
Gary
