Old 03-27-2014, 07:20 AM
YerDugliness's Avatar
YerDugliness YerDugliness is offline
Cobra Make, Engine: Cobra Auto Works body, Ron Godell Racecars chassis, 1989 Mustang GT 5.0 HO (converted to carb), W/C T-5, 3.73's in a Ford 9" Traction-Loc.
Originally Posted by bobcowan View Post
If you're not getting a spark, it's probably the Mallory module. They have a nasty habit of failing; and it doesn't take much. I went through about 4 of them before I finally figured out it was the main battery switch. I know it's expensive, but replace it anyway. If that's not the problem, you'll have a spare. Eventually you'll need it.
Do you have circuit protection for the distributor? If not, you should install one. It's cheap and it works.
http://www.summitracing.com/parts/maa-29351/overview/
Bob, is the item in your attached photo the Mallory version of a ballast resistor, or is it a different item with a different function?
I have no problem with spending the $$ it will take to make the system operational and my primary goal is reliability...my area of TX has quite a few National Forest areas and the car is used frequently for jaunts in areas where there is little in the way of civilization or help, so I am motivated to make sure the repair is durable.
I am convinced the control module needs replacing. I think I will replace the ballast resistor, too, and if the item in your post is a different item with a different purpose I will install one of those, too.
I want to fix it once...have no interest in short cutting the repair process or skimping on quality.
Thanks!!!
Dugly
YD,E./PNB
No names were changed to protect the innocent!
