Thread: Bad Starter
Old 03-29-2014, 07:12 AM
patrickt patrickt is offline
Originally Posted by Large Arbor View Post
Ok, so I discovered with a good ground it all engages and spins. I am thinking that I just need to run a ground wire to the case of the starter and it should solve the problem.
Yep. Inspect the ground cable from the battery negative terminal over to the passenger side head, or wherever your black cable terminates. Take it apart, look at it, wiggle it in your hands, clean it up, and put it back together. Usually a starter is pretty well grounded just by being bolted up to the engine.
