Old 03-29-2014, 06:14 PM
Shootnride's Avatar
Shootnride Shootnride is offline
Cobra Make, Engine: Superformance, 427SO
The holes are mirror backwards. On a Windsor, the passenger side hole is higher, on the FE, the driver's side hole is higher.
This should be very easy to resolve with a flat, square, adaptor plate that has both bolt paterns if there is clearance for the square plate. Through-bolt the tank flange to the adapter plate, then bolt the adapter plate to the engine. Gasket both sides.
Ted
