Old 03-30-2014, 01:52 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Clearly no combustion on those 3 cylinders.
Tight valves, low compression, weak or no spark, or blocked idle jets.
Have you checked all the above, including carb airflow balancing?
What baseline carb calibration (idle jet, main, emulsion tube, etc) are you using?
Gary
