In a perfect world the PVC valve will have its own vacuum source and so will the brake booster. Sometime people T and connect both to the same source. Ok for temporary. Scof has a solution if u only have one source. You drill through an existing boss on the manifold and install a 1/8" not nipple. U most stop the shavings from going into the cylinder.
