Old 04-02-2014, 01:56 PM
Chilibit Chilibit is offline
Cobra Make, Engine: Superformance, Roush 402R, Kentucky Cobra Club
If you go to SCOF and look you will find that the isolated "wobble" is something they think is related to a suspension piece. I forget just what it is. I don't seem to have a problem on my car. You could raise the front end and spin the wheels to see if there is run-out or an out of round condition. I suspect the answer is on SCOF and it is not the tires or wheels. Positive camber does not sound right nor inviting. Are you at the limits of alignment adjustment after raising? Did you raise as a part of corner loading? My AVONs balanced easily, ran true and the difference in wear was 1/10 mm across the tread. Close to perfect. Olthoff aligned it and I have not touched it in 35k miles. Maybe more. I have a Smiths speedo. Smile. Actually it works---good enough.
My new set of AVONs is in the garage sitting on the trailer until I pull the wheels. Please let us know what you find.
