Old 04-05-2002, 06:35 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
As it turned out the overheating was the result of three bad sending units. I finally borrowed a laser pyrometer and checked each cylinder wall, radiator, water pump, oil pan, etc., each check out OK. Then I boiled some waster and put my thermostat in and checked when it opened and the reading of the gauge. I had bought these (last 2) gauges from the same source within days of each other. The gauges were fine except the sending units were mis-calibrated. I changed so many things that I may have had a problem caused by several things but all seems to be ok now. My gauges were reading almost 100 degrees hotter than the actual temp.
"Let's roll"
"Be part of Something Good
