Thread: Vapor locked
Old 04-05-2002, 07:21 AM
Coloradocobra Coloradocobra is offline
Default Spacer?
Hi Bran,
Are you running a carb spacer? I don't know how much clearance you have with the 460 but a 1" or even 1/2" spacer may help to keep some of the heat out of the carb. Also, check where you are running your fuel lines to the pump and from the pump to the carb to make sure they are as far away from major heat sources as possible. With our high altitude and the newer fuels, vapor lock is a real problem. I run a mechanical and have never had any pressure/flow problems or vapor lock so far.
My carb problem was similar except I was having float problems. After only minor heat soak, the floats were not keeping the needles properly seated and I ended up with too much fuel - everywhere. New off road seats from Holley have correct this issue - so far. After you get your car hot, let it idle and take the air cleaner off. Grab the roll bar and shake the car as hard as you can and look for fuel spraying up through the vent pipes.
Call me if you need any help. We don't want it to vapor lock on the dyno on the 20th!
Gary
