Old 04-09-2014, 11:28 AM
skullandbones's Avatar
skullandbones skullandbones is offline
Cobra Make, Engine: FFR MkIII #6046 SBF
I have such a Frankenstein setup that I didn't expect the cable to work at all. So I ordered some quadrant ends from McMasters. I happen to have the swedging tool from a former business so it was easy. You could take it to a shop to have that swedged as well not much cost. Long story short: I have a custom length cable that fits perfectly. BTW, make sure everything is in the correct position before you measure and cut your cable such as the firewall adjustment, pedal height, quadrant position, etc..... That way you will have the full range of adjustment for your new cable. I can post the part number if you are interested. Good luck, WEK.
