Old 04-11-2014, 05:23 AM
mnm99's Avatar
mnm99 mnm99 is offline
Originally Posted by CBattaglia View Post
They were cool with me when I registered mine. Needed padded visors, so I put green foam around them for the inspection. The guy laughed and said it meets specs.
DOT lenses are easy, I did put in a back up light under left rear, I intended on removing it after inspection but it helps... So I left it.
Documentation on motor and trans was mandatory though. As for emissions that is determined by the year of the motor. As long as your block is pre 73' you are good to go.
That's the problem I'm having. The ones I'm looking at nobody has the receipts for the motor and trans. Second owners. Are crate motors Okay?
