Old 04-11-2014, 10:20 AM
DanEC's Avatar
DanEC DanEC is offline
Check those pesky fast blow fuses on the steering column. If they haven't blown, check to see if you're getting a +12v feed to them.
I will. It's probably going to be Monday before I can look at it. It could be something as simple as a ground I didn't put back when I installed the trunk carpet or the connector to the rear wire harness. Or maybe it's that ground stap I lack from the engine to the frame.
Dan
