Old 04-14-2014, 11:06 AM
DanEC's Avatar
DanEC DanEC is offline
Bob - I hope I did this right.
I switched the B/W and B/G leads from the turn signal to the respective Y and G leads to the relay. When I did that the left front signal flashes when I signal right. Again, the left rear signal will flash when I press on the brake pedal. Still nothing on the right side in terms of any signaling.
Edit - looks like you meant to switch at the screw contacts on the fuse board. I will try that too.
